TSReader | Archivostv
TSReader
josagi
25 Ene 2017
TSReader Lite 2.8.48a
Version 2.8 build 48a:
Known issues
Captions from H.264 streams are not saved correctly in archive mode
Captions carried in SCTE-20 format and written in the archive mode will sometimes be jibberish
The HTTP source runs at the rate the server will dole out data and not at the mux speed
Changed in 2.8, build 48a:
All: Added support for the Blonder Tongue MTSA device. This supports 8VSB, QAM-B, ASI and SMPTE-310M inputs and ASI & SMPTE-310M output in TSReader Pro
All: Display of the SDT version number
All: Fixed the Sencore/Dektec DTU-236 source module to correctly detect front-end lock and switch cleanly between RF & ASI inputs
All: Fixed missed DiSEqC commands on some TBS DVB-S/S2 satellite cards
Pro: Added the ability to record 10 second files in the archive function.
All: Updated to Alitronika's latest API
Pro: Fixed an issue with exporting CUE messages to XML
All: Added decoding of the resolution of H.265 video streams
All: Added chroma and luma bit depth for H.265 video. Anything above 9 bits is considered HDR
All: Added support for the TBS 5927 tuner
All: Fixed an issue where right clicking a DVB NIT and selecting "Tune to this mux" would fail on TBS DVB-S2 cards
Std/Pro: Fixed an issue with the -I switch not working on DSS muxes and dropping source module parameters
All: Improved the reliability of the H.264 thumbnail decoder
Std/Pro: Fixed a crash on XML export when hundreds of programs are defined in the PAT
All: Added support for SAT>IP tuners
https://mega.nz/#!7B1VHZhA!J1HTa6ya2d-lKSxnqTINtb0LU_kFtd_6CMe676U5TzE
josagi
25 Ene 2017
TSReader Lite 2.8.48b
Known issues
Changed in 2.8, build 48b:
All: The easy reader and widescreen flags in the ATSC caption descriptor are now displayed
Std/Pro: Fixed an issue with XML and XMLTV export where the wrong options were displayed when choosing the output file
Std/Pro: The SAT>IP source module now supports the tuner address and number on the command line in the format [tuner-address:tuner-number]
Std/Pro: Added the DVB EPG category to XMLTV exports
All: The HTTP source module now understands .m3u files without the need for them to be described by an HTML 5 <video> tag.
All: HLS/MPEG-DASH live streams are now supported by the HTTP source module
Pro: The ccextract command-line utility now processes captions from H.264 video
Pro: XML export now includes SCTE 35 cue messages in raw hex format
Pro: The Stream Monitor window is now bigger so the entire alarm text gets displayed
Pro: Added a button to copy all the Stream Monitor alarm text to the clipboard
Pro: Added a function to the Stream Monitor to generate an alarm if a certain PID's bitrate drops below a certain level. This level can be set by clicking the Settings button in the Stream Monitor window
Std/Pro: Added the ability to save MPE IP data not carrying UDP or TCP traffic
Pro: Added the ability to log all SCTE-35 messages into a comma separated file
Pro: Fixed an issue where H.264 captions would sometimes be gibberish if B slices were present - fix applies to both TSReader and the ccextract command-line program
https://mega.nz/#!rMEjkIRB!1wDPkFDzWr9qO7PsKoJ7m2vYHs2MwA0cl9fL9mU_R5g
josagi
25 Ene 2017
TSReader 2.8.53a
(Full version)
https://mega.nz/#!zIBhVIyR!QCeRTfBmzpGCsGx_x8R6R6raLbIWoO8OxV9CR0CnCvo
