Tivu Stream Plugin by Lululla | Archivostv
josagi
25 Ene 2017
204
@ Lululla wrote:
Hello everyone
we are pleased to present an E2 plugin TiVu Stream that installs the channel lists:
iptv with about 3000 streams currently
Thanks to the BandbSat forum that made the server available
and to the work done by @buio2005 for this.
Soon there will also be a version for Android (apk) and Kodi & Kodilite
Still in the testing phase but I think the best way to know is to test it.
Very simple to use and also very light
Password for XXX channel download:
put in config : 1306
-tivustream.tar put in /tmp and command console telnet: tar -xvf /tmp/tivustream.tar -C /
-enigma2-plugin-extensions-tivustream_1.0_all.ipk : put in /tmp and command console telnet : opkg install --force-overwrite /tmp/*.ipk
-enigma2-plugin-extensions-tivustream_1.0_all.deb : put in /tmp and command console telnet : dpkg -i /tmp/enigma2-plugin-extensions-tivustream_1.0_all.deb
Reboot gui
Ps.:
unfortunately the Free IPTV Pandasat plugin will not be updated anymore nor the lists of that plugin.
So we decided to make a new lugin on a more stable server.
enigma2-plugin-extensions-tivustream_1.0_all.ipk.rar
https://mega.nz/#!qFMRwSpb!ZQgSWZcEGMyzLLS2D9dWIN0MD5XCqtOjoTk-KosCoz4
enigma2-plugin-extensions-tivustream_1.0_all.deb.rar
https://mega.nz/#!vAEDhZJK!7hhQIAlIhdTQXZEDjvCjbQSPBYrk8XGclG8w7rqADOE
tivustream.tar.zip
https://mega.nz/#!7FlVSRjY!Ns5BWmbEB195NZPzItubArKpoP86l7jJUc3EMr2nSK0
josagi
25 Ene 2017
204
Update: V.1.2
-added in the config the possibility to choose a second server from where to download
-Select CORVONE in config and everything works
-Until we solve a problem in the central server
enigma2-plugin-extensions-tivustream_1.2_all.ipk.zip
https://mega.nz/#!KVtmkCAb!dViTLf8po8xayUKPot4tE6o1AP89-xIh57KnwNEGCLo
josagi
25 Ene 2017
204
Update to v.1.4
Changelog:
-Fix Update
-Fix Skin
-Fix Server added Corvoboys
-Fix Minor
Tested on PLi base image (OK)
enigma2-plugin-extensions-tivustream_1.4_all.ipk
https://mega.nz/#!aF02iYAQ!dvKjzJYV45x2N1lLGrhhLTyV_07FTctzAx78u6SgdwQ
josagi
25 Ene 2017
204
Update to v.1.5
Changelog:
- Fix Skin crash
- Fix Minor
Command Telnet .tar
wget http://patbuweb.com/iptv/plugin/tivustream.tar -O /tmp/tivustream.tar > /dev/null
rm -R /usr/lib/enigma2/python/Plugins/Extensions/TivuStream
init 4
killall -9 enigma2 > /dev/null 2>&1
init 3
Info:
for the XXX Adult list a new password is required
Please send email to
tivustream@gmail.com
with subject: "Password request"
enigma2-plugin-extensions-tivustream_1.5_all.ipk
https://mega.nz/#!6IMBwYzI!eOtHnipTvWXjjgmit6xuUQqGlt20C8bUtrV1UfWjrWY
