OSCam Aarch64 Binaries for (EdisionOs Mio4K & Vu+Plus Duo4k) | Archivostv
josagi
25 Ene 2017
OSCam_svn1.20-rev-11495 -emu-r788
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11495-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!2E9iCQyA!ghvYOwUGqWhtUm-xiM6UKbI6WLDadTzCT2-NVcuWiz0
josagi
25 Ene 2017
OSCam_svn1.20-rev-11497 -emu-r788
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11497-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!CdMzXSBL!kwymY55mclYQ2wUbNKNlMbpOwAvh0wgZwfQjsblxaQs
josagi
25 Ene 2017
OSCam_svn1.20-rev-11501 -emu-r789
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11501-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!uAVCTAYY!6ryr_04olcwNedEHl5oLQ-kHPcndPeZrGgY1ODx97xQ
josagi
25 Ene 2017
OSCam_svn1.20-rev-11504 -emu-r790
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11504-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!zZ9g2CYY!B355l4xdiYw1F0oamoSdN-hRnvyZnnU3BjOjOCsVJ9o
josagi
25 Ene 2017
OSCam_svn1.20-rev-11505 -emu-r790
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11505-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!DQlDnYYZ!1_rBl70GYfIawJ3zFz4VocNpx32MWUfs4_H9su1wTVc
josagi
25 Ene 2017
OSCam_svn1.20-rev-11505 -emu-r791
Emu r791:
  • Added support for PowerVu hash mode 0, 11, 12, 13, 14 and 39
  • Fixed potential deadlock in powervu emm handling
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11505-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx (1).tar.g
https://mega.nz/#!jRVUHAoD!EwA-2QsW-wfzZpdPnXYUxYIzI_8X2P7RqMoK5t7A7T8
josagi
25 Ene 2017
[*]Emu r791:
[*][powervu]
[*]- Added support for hash mode 31
[*]aarch64 processor
[*]Edision OS Mio 4k
[*]VU+Plus Duo4K
Thanks @audi06_19
https://mega.nz/#!rEVmFQKD!D-m5emeZ6iYv0Fu9IsZsRlLKePlUTEO7RQsgZ52jy8c
josagi
25 Ene 2017
OSCam_svn1.20-rev-11505 -emu-r792
- Added support for PowerVu hash mode 31
  • Fixed cw checksum bytes for Director nano EE
  • Other small optimizations and improvements
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
https://mega.nz/#!yMM0VQiQ!PkyVbM7bzPDkZ3Q-f66rQfViRrqBT3Ubglfw-nsJ7i8
josagi
25 Ene 2017
OSCam_svn1.20-rev-11507 -emu-r793
Emu r793:
  • Added support for PowerVu hash mode 32
  • Added new config switch --emu-version (returns 793)
  • Existing config switch --oscam-revision (returns 11507-793) does not depend on git "tags" now
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11507-aarch64_osmino4k-vuduo4k-web
https://mega.nz/#!7JEz0KqQ!8wkG_Crd8xOXZMq1IWz4DA9sHsnNNQvx75hi7RvdWqE
josagi
25 Ene 2017
OSCam_svn1.20-rev-11508 -emu-r794
Changeset [11508] 06.04.2019 20:30:44
first part of the rework on dvbapi
to incrase the amount of descramblers
Get available descramblers in box and BISS2 related changes
  • Instead of using a predefined number of descramblers (16 until now), oscam now gets the exact number of available descramblers in box.
  • Skip cw checks for BISS2, similar to what is done for BISS1. BISS2 uses 16 byte cw, so some checks need to be skipped.
  • Cosmetic changes including code refactoring, variable renaming and comment addition to several places.
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11508-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar
https://mega.nz/#!LVNDQI5Z!J0y2-NS95Jmtjkjspw8x4o9GSMgzZLq3hpe_w9Juw_E
josagi
25 Ene 2017
OSCam_svn1.20-rev-11510 -emu-r795
Changeset [11510]
-small text typo fixes
aarch64 processor
Edision OS Mio 4k
Vu+Plus Duo4K
Thanks @audi06_19
oscam-svn11510-aarch64_osmino4k-vuduo4k-webif-dvbapi-libusb-emu-upx.tar
https://mega.nz/#!GZMB1SLD!A-LL5sRgfWJ5cVp8c-GRu0dqRjAqHIVSUtIXMDhPBkA
josagi
25 Ene 2017
OSCam_svn1.20-rev-11517 emu 795
Changeset [11517]
  • fix bug in disablecrccws_only_for also in cacheex
  • general disable checksum correction code optimization
thanks audi06_19
oscam-svn11517-aarch64_osmino4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!GZl1iCoR!85h1QufcmIocQsRPn9VObjudOGxpkNJcAo9sG-Oy0ZA
josagi
25 Ene 2017
OSCam svn11518 Emu-r796
thanks @audi06_19
Changeset [11518]
-Fixed bug in dvbapi not releasing used descramblers in stapi, coolapi and gxapi boxes
-Increased MAX_STREAM_INDICES back to 32 (it must be equal to MAX_STREAM_PIDS)
-Modified the get_emm_filter_adv() function to accept more arguments
-Cosmetics to module-cccam.c and module-cccam-cacheex.x
-Removed some emu specific code not needed anymore
Emu r796:
-Added a new method for matching powervu keys *
-Dropped unused videoguard and drecrypt modules
-Other small optimizations and improvements
oscam-svn11518-aarch64_osmino4k-webif-dvbapi-libusb-emu-upx.tar.gz
https://mega.nz/#!DNEmDAQQ!QuogjL3UfKqz4O6xy_PIrgFHfUdbiVbU8nlqLuhMbWQ
josagi
25 Ene 2017
OSCam 11.520-emu-r796
Thank you: audi06_19
11520 gorgone.impertinence 02.06.2019 14:45:14
Added support for a higher number of demux devices in CA PMT
Modern enigma2 boxes with FCB tuners can have many demux devices,
so a new CA PMT descriptor that allows up to 128 demuxes (descriptor tag 0x86) is now supported.
Also, the get_demux_options() function is completely re-written,
so it doesn't care for the order of descriptors inside the CA PMT message.
+ disablecrccws_hardcoded_for_Sky_and_Dorcel.patch by Pehedima
- 098C , 09C4 , 098D , 0500:050F00
Added new tandberg keys *
oscam-svn11520-osmio4k-webif-dvbapi-libusb-emu796-upx.tar.gz
https://mega.nz/#!LMUi0ayY!JRnB9btBXeJ2st6rumPvVXF5JwHWvfBsgJhLEolBXTE
