m3u2bouquet Plugin | Archivostv
m3u2bouquet Plugin
Usuarios que vieron este tema (Total:12)
josagi
25 Ene 2017
m3u2bouquet V.0.7.3
whats new:
-Fix issue with main screen showing no text on some skins
-Add option to reset bouquets
notice:
-all data information & configuration is now in path -- /etc/enigma2/e2m3u2bouquet/config.xml
-open plugin & go to configuration where u shall input all data & details of your iptv chs m3u link
Adjuntos
josagi
25 Ene 2017
V 0.7.6
-Add nocheck attribute for EpgImporter sources (fix for new EpgImporter version)
-Add m3u8 VOD stream matching
We’ve had some reports of issues with epgimport .
Initial investigation suggest that a recent epgimport update will stop it from working with any panel’s epg feed.
We’ll investigate further but in the meantime we suggest not updating to the latest epgimport version.
Update
This issue is caused by the latest version of epgimport checking for a ‘LastUpdate.log’ file on the server that supplies the xmltv epg feed. If the file doesn’t exist or the date within is older than 2 days then the server is considered invalid and not used. Unfortunately this file is used by Rytec feed servers but not IPTV panels.
We’ve released v0.7.6 which sets a flag in the epgimport sources to ignore this check however this flag has only recently been added to epgimport and at the moment only works on the OpenPLI branch and not the OE-Alliance fork. Hopefully the OE-Alliance fork will merge this feature soon.
TL;DR
New versions of epgimport have broken the epg for IPTV panels. You should avoid updating epgimport for now, or revert to a previous version.
Updating to v0.7.6 of this script/plugin should fix the issue on OpenPli and hopefully future OE-Alliance images.
enigma2-plugin-extensions-e2m3u2bouquet_0.7.6_all.ipk
https://mega.nz/#!3JkQwK4L!l-SnCF8LG_iSUliAUipJVbnwJEoXtfHSNsQKuRO0lXM
josagi
25 Ene 2017
e2m3u2bouquet 0.7.7
whats new:
-Set extensionless streams as live TV
enigma2-plugin-extensions-e2m3u2bouquet_0.7.7_all.ipk
https://mega.nz/#!iQtExQbQ!2VML7OBizrpClO-ZBuo_cSYTreErj5ZLP25Eri4p6hI
josagi
25 Ene 2017
enigma2-plugin-extensions-e2m3u2bouquet_0.8.1_all
whats new:
-Fix issue where new providers couldn't be added
-When providers bouquet is downloaded (-b or -bd option) now uses full
service references
instead of just the epg relevant part in case it's used for picon naming
-Better multi provider handler e.g. if there is an issue with one provider it
won't stop the script processing others
-If vod categories are out of order in the playlist group together
-Fix file naming issues with non alphanumeric characters
-Much faster when using an override file :)
-Don't retry failed picon downloads
-Option to add placeholder channel in override file (to control channel numbering)
-Allow channels to be moved between categories, use categoryOverride in the override file
-All custom categories, use customCategory="true" in the override file
-Add provider managed update support
enigma2-plugin-extensions-e2m3u2bouquet_0.8.1_all.rar
https://mega.nz/#!HZNRWYBR!zrfIpD8MubZo4mNFo13GNiQFTU8XlKr41RB8VHkL1TM
josagi
25 Ene 2017
Version .0.8.2
  • Download the ipk and ftp it to the /tmp folder on the box. N.B. if the config.xml file (see below) is in the /tmp folder it will also be installed if an existing one doesn’t exist
  • Either install it from the box GUI (in OpenVix this will be ‘Menu -> Setup -> ViX -> Install local extension
    or SSH/Telnet to to the box and run
Importing EPG Data
  • Open EPG-Importer plugin (download it if you haven't already got it)
  • Select sources (Blue button on OpenVix)
  • Enable the source created by the script (listed under IPTV Bouquet Maker - E2m3u2bouquet)
  • Kick off a manual EPG import
Add Plugin install Generator Attached
You can also download a generator that will let you enter your details and generate a one line install command with the plugin preconfigured. Right click on the following link select ‘save link as’ and then save to your PC – generator download. You can then run the generator by opening the downloaded file.
Open your plugins menu, there should now be a plugin named ‘IPTV Bouquet Maker (IPTV for Enigma2 – E2m3u2bouquet plugin)’
enigma2-plugin-extensions-e2m3u2bouquet_0.8.2_all.ipk
https://mega.nz/#!nJtxwYTR!zWyUt1X7t9qNuvhJqfqF2YSXHe130I4FvYZDdNixAmM
generator.rar
https://mega.nz/#!PZkzEYyD!ExxxNfSFo3ot3tZZ0R_FnzdP9Ai10gRROgLt6nbJPSY
josagi
25 Ene 2017
Enigma2 IPTV M3u to Bouquet EPG plugin
[OE2.0 & OE2.5]
OE2.5 Images Mod: audi06_19
https://github.com/su1s/e2m3u2bouquet
https://www.suls.co.uk/enigma2-iptv-bouquets-with-epg/
enigma2-plugin-extensions-e2m3u2bouquet_20190709-r0.8.2_all.ipk
https://mega.nz/#!XccUiC4R!sfesgeGhhzEwpH1a5rl3Hbm_-MQYqhI3uHoZjAV0U94
enigma2-plugin-extensions-e2m3u2bouquet_20190709-r0.8.2_all.deb
https://mega.nz/#!jQVyxIgZ!PAN3rMAb6BjLAWvQCz6urLS0AYyx1HholuC20TwEInU
