LAV Filters - DirectShow Media Splitter and Decoders | Archivostv
josagi
25 Ene 2017
LAV Filters 0.71
General
- LAV Filters now requires Windows Vista or newer, Windows XP is no longer supported
LAV Splitter
- NEW: Preliminary support for UHD Blu-ray parsing
LAV Video
- NEW: D3D11 hardware accelerated decoding (native mode with madVR, Copy-Back otherwise)
- Fixed: HDR metadata was not properly communicated to madVR in DXVA2-Native mode
- Fixed: Anamorphic WMV9/VC-1 videos were not being played back with the correct aspect ratio in all cases
- Fixed: Changing certain settings while playback was paused could result in a deadlock
- Fixed: Playing severly corrupted HEVC streams with hardware decoding could result in playback failing entirely, instead of skipping over the corruption
LAV Audio
- NEW: Basic support for AAC 960 streams (common in DVB radio streams)
LAV Filters 0.71
LAV Filters 0.71 64-bit
LAV Filters 0.71 portable
LAV Filters 0.71 portable 64-bit
josagi
25 Ene 2017
LAV Filters 0.71.0-49
LAV Video
- Changed: Enabled CineformHD decoding by default, since the decoder has much improved
- Fixed: Decoding Matroska files with Linked Segments which used old x264 4:4:4 encodes could result in corruption
LAV Audio
- NEW: Blu-ray Dolby Digital Plus 7.1 decoding and bitstreaming support
- Fixed: DTS-HD HRA bitstreaming did not work properly with many A/V receivers
- Fixed: TrueHD bitstreaming could result in drop-outs on high bitrate TrueHD+Atmos streams
LAVFilters-0.71.0-49.exe
josagi
25 Ene 2017
LAV Filters 0.71.0-56 Nightly
LAV Video
LAV Audio
LAVFilters-0.71.0-56.exe
josagi
25 Ene 2017
0.73.0 - 2018/10/05
LAV Splitter
Changed:
Export the description of cover art and attachments for use by players
Fixed: Properly marked the packet allocator as providing read-only packets, to avoid crashes with in-place transform filters
LAV Video
NEW:
Support for AV1 decoding using libaom
Changed: Enabled VP9 hardware acceleration by default
Fixed: The aspect ratio of certain WMV/VC-1 files was not being properly respected in the WMV9 MFT decoder
AVFilters-0.73-Installer.exe
https://mega.nz/#!rYVgDCqL!q-Z4ck5kNeVGyoF9DD51aRqHf0rpXtgHmSzjzM1iqew
