KodiLite for Enigma2 | Página 3 | Archivostv
Usuarios que vieron este tema (Total:2)
josagi
25 Ene 2017
KodiLite V.4.0
Plugin KodiLite version 4.0 is being currently developed. The purpose is to be able to use any working Kodi addon directly in KodiLite without change. Please install the attached KodiLite.v.4.0 and test with Kodi addons.
New addon install methods are in 'Install addons' (green button on first screen).
For the option 'Install from User list' - please put the addon (plugin, script or repository) and the download link in the plugin file /KodiLite/useradlist.txt using the syntaxt :
addon-name###download-link###
Another new option is to install from Fusion.
thanks pcd
enigma2-plugin-extensions-kodilite_4.0_r0_all.ipk.zip
https://mega.nz/#!OUcHFQ5T!sL2K05pwXN3p-vaSBms0Yf3eVR-nBNhptdw2WTsoUnI
enigma2-plugin-extensions-kodilite_4.0_all.deb.zip
https://mega.nz/#!OB8gXDCL!JMv5tbdalN7FY7pkxTDq59J6P1cnVI0hPkLzM5zF9z4
josagi
25 Ene 2017
New & Updated Addons
11.11.2017
ADDON INSTALL METHOD : Ftp the .zip file to folder /tmp. Next start plugin KodiLite -> Install addons (green button) -> Install from/tmp.
Attached below are five updated Albanian addons which work in both KodiLite 4.0 and Kodi.
plugin.video.azfilma-al-1.0.1.zip
plugin.video.ckamekqyr-1.0.0.zip
plugin.video.tvseriale-1.0.0.zip
https://mega.nz/#!DJsySYrY!dkgq5NZUl5wNR5mKJ0zCNr73Kli6tRwJMIXWW9vk_R4
piri
4 Nov 2017
hola,gracias por la informacion muy bueno.
josagi
25 Ene 2017
19.11.2017
plugin.video.tvseriale-1.0.2
https://mega.nz/#!7I8DhBhD!ZN9Qxu4z38pZhO5GPLas6Mo1_Ei6uQaNa_3hIjBIrS0
josagi
25 Ene 2017
KodiLite V.4.0 Final
Plugin KodiLite version 4.0 is attached below. The purpose of the new version is to be able to use any working Kodi addon directly in KodiLite without change. Apart from generally available Kodi addons - there are also a large number of addons especially developed for KodiLite.
The following addon install methods are in 'Install addons' (green button on first screen) :-
1. Install from zip -install addon zip files (plugin, script or repository) in /tmp, /media/usb or /media/hdd
2. Install from KodiLite list (/KodiLite/adlist.txt) - KodiLite team tested addons are listed here
3. Install from User list (/KodiLite/useradlist.txt - please put the addon (plugin, script or repository) and the download link in the plugin file /KodiLite/useradlist.txt using the syntax :
4. Install from Kodi official repositories
5. Install from User repositories - first install your repo via method 1.
6. Install from Fusion
Thanks @pcd.
enigma2-plugin-extensions-kodilite_4.0_r0_all,ipk.zip
https://mega.nz/#!WEVSwRaR!aIVzQLhKIJLoG9T2XmQzNWFlu84cL9MLD4z9AouHt1Q
https://mega.nz/#!HcVHVSaC!M8ptvOcdksydHuesE0NeS-pN7ENnNaYrBIk5FEGt8Rc
j13txos
29 Ene 2014
Josagi necesito de tu sabiduría. No entiendo por que no se me actualizan el Covenant y el el Neptune de este plugin. No me salen películas nuevas. Si me pudieras ayudar.
Muchas gracias.
j13txos
29 Ene 2014
Tengo un vu+ ultimo con la blackhole 3.0.5.
Ayuda. Muchas gracias.
josagi
25 Ene 2017
Plugin KodiLite Installer
for USB, External HDD and Normal Installation
Version 1.0
pcd wrote:
Plugin enigma2-plugin-extensions-kodiliteinstaller is attached below. It can be used to install complete plugin KodiLite on a usb stick or external hdd - and also as normal in internal /Plugins/Extensions.
After first time start of KodiLite - Exit and Restart enigma. Please note that any already installed KodiLite will be deleted.
Installing KodiLite externally can make some operations faster and also useful for boxes with limited flash memory.
Adjuntos
josagi
25 Ene 2017
KodiLite V.5.0
The plugin is now made more simple to use.
This version already includes a number of requested addons.
Included addons :-
Showtime
-NeptuneMovies
IPTV
-iptvday
-m3uliste
-m3uplayer
-SportsDevil
Youtube & Co
-youtube
Albanian
-filmi24
-tvseriale
Italian
-tivustream
-videomediaset
Turkish
-turkvod
Adult 18+ (protect with parental PIN)
-16 adult addons
enigma2-plugin-extensions-kodilite_5.0_r0_all.ipk
https://mega.nz/#!id12kC6Q!pAkU4Voc8GCI11mjZryc_Wbujh6GzgnJs-uvgaIFhmc
enigma2-plugin-extensions-kodilite_5.0_all.deb
https://mega.nz/#!mB8wASiT!u9TrqcR2q399kojUxf_8mIiwpPzBInxQ13IGDn9LbZ8
josagi
25 Ene 2017
12.08.2018
Unzip and ftp to plugin folder /KodiLite/ADULT.
Restart enigma.
Adulttv-1.0.7.zip
https://mega.nz/#!uUMzGQSD!cur6YIsZiS1pxW4syN6a58h9D8eRDNE0sEgfi4K_Q68
josagi
25 Ene 2017
11.08.2018
Addon palantir and cine are attached. Please unzip and ftp the plugin.video items to folder /KodiLite/USER and the script.module items to /KodiLite/scripts.
Restart enigma.
Palantir-0.0.47.zip
https://mega.nz/#!OUVHFaLQ!Wz3GceIqCBUxVpOTb5NE7M4Yrb6unSZh1FcN3QotJmU
cine1.0.67.zip
https://mega.nz/#!qZVn1QwC!kO3TzSVA0LkwQZZD3Dmk_Wm_0728M9oCa4w9qz8jKvU
josagi
25 Ene 2017
14.08.2018
Please unzip and ftp to plugin folder /KodiLite/ADULT.
motherless-1.0.1.zip
https://mega.nz/#!iR9TUTpC!KtfZ7LmHxWu71w3diZzwNcy10VXLK5RThbbCWtt3DPM
josagi
25 Ene 2017
Showtime addon FrenchMovies-1.0.1 - ItalianMovies-1.0.1 - SpanishMovies-1.0.1 needs updating.
Please ftp the plugin.video to /KodiLite/MOVIES . Restart enigma. Regards.
plugin.video.SpanishMovies.zip
https://mega.nz/#!zBNAAK4K!bqerKrzN8-szVIyXY_N2VDTbu9UYVEhEuk4F1I8uxuE
plugin.video.ItalianMovies.zip
https://mega.nz/#!TVMQlQAZ!oyEQ6CISIdUG5U0_ZJuG-tnacxWpwERgyV3Mnj0s7XQ
plugin.video.GermanMovies.zip
https://mega.nz/#!LFUwXSRQ!_TEckIQL1OIybNPEljBd6Srqoq0nf04XTZT90Y5in3s
plugin.video.FrenchMovies.zip
https://mega.nz/#!7ZEwmKra!Xpoz80dTc7cXLhQyTs6Lq9sRxLkt68pg4JkduAL0Hpo
josagi
25 Ene 2017
plugin.video.filmphp-2.0.1.zip
Please unzip the attached and ftp the plugin.video to /KodiLite/IPTV and the script.module items to /KodiLite/scripts
plugin.video.kodispaintv-2.3.zip
plugin.video.iptvts-1.0.2.zip
https://mega.nz/#!TANXFC5a!wFfQmxKqdNOPmB2alBcILHJ5XguFAZp3PnPH6emoJDc
https://mega.nz/#!iRFTFYjJ!udRQCiJG24LLXbMJOMbF8bnK0hvt2d3O8_UvZJJWM8Y
https://mega.nz/#!iBMhjIqI!Vgt2JBm8S_4MYJ-BpoxQHOYBuweK-54RBqYZWhZCaoo
j13txos
29 Ene 2014
Buenas, un poco de ayuda. Instalo los scripts y luego pongo el plugin kodispain pero no me funciona.
Lo pico pero no se carga nada, que pueda ser?? Alguien sabe que puede ser??
Si no te pido consejo gran Josagi.
Muchas gracias
j13txos
29 Ene 2014
Alguien que utilice el Spanish movies o Neptune??? Es que me sale el siguiente fallo cuando ya entro en los servidores de bajar la pelicula:
Error! Try another ítem Or exit and submit lo /tmp/.e.log and /tmp/error.log
josagi
25 Ene 2017
New and updated addons (install via KodiLite ->Install addons -> KodiLite list) :-
plugin.video.iplayerwww-3.0.36 - TV & IPTV - Categories and Live worked
plugin.video.itv-2.5.9 - TV & IPTV - Shows worked with Play via F4mTester
plugin.video.cine_es-1.0.68 - International/Spanish
plugin.video.palantir-0.0.47 - International/Spanish
Please press the Like button if you want these to be maintained. Thanks.
Regards, pcd.
josagi
25 Ene 2017
plugin.video.videomediaset-1.9.3 - International-Italian - First install script.module.phate89 from
KodiLite list->scripts (delete any installed version)
plugin.video.YTplus-2.0.6 - Youtube & Co - First check installed plugin.video.youtube is working
plugin.video.porncenter-1.0.1 - Adult 18+ - Four new websites - Thanks zigzag for suggestions
Regards, pcd.
josagi
25 Ene 2017
plugin.video.streamondemand-pureita-5.4.9 - International-Italian
plugin.video.AdultTV-1.0.8 - Adult 18+
plugin.video.filmi24-1.0.3 - International - Albanian
plugin.video.filmi24seriale-1.0.2 - International - Albanian
Regards, pcd.
josagi
25 Ene 2017
2018.12.19
Hello Friends,
plugin.video.EnglishMovies-1.0.4 - Movies
plugin.video.ItalianMovies-1.0.3 - International-Italian
plugin.video.SpanishMovies-1.0.4 - International-Spanish
plugin.video.GreekMovies-1.0.2 - International-Greek
plugin.video.PolishMovies-1.0.3 - International-Polish
plugin.video.FrenchMovies-1.0.3 - International-French
plugin.video.GermanMovies-1.0.4 - International-German
Servers openload and streamango are reliable (openload needs pairing).
Regards, pcd.
josagi
25 Ene 2017
2018.12.27
Hello Friends,
Wish you All a Very Happy New Year !
plugin.video.turkvod-3.1.9 - International-Turkish - get your receiver mac address from telnet
command ifconfig (find HWaddr) and insert it in /resources/settings.xml
plugin.video.jizzplanet-2.1.0 - Adult 18+
plugin.video.mcadult-1.0 - Adult 18+
plugin.video.TAD-1.0.1 - Adult 18+
plugin.video.tubeshemales-1.0.3 - Adult 18+ - re-install script.module.XXXresolver
Regards, pcd.
josagi
25 Ene 2017
2019.03.18
Hello Friends,
plugin.video.cine-1.0.71 - International-Spanish
plugin.video.palantir-0.0.51- International-Spanish
Regards, pcd.
