KodiLite for Enigma2 | Archivostv
Usuarios que vieron este tema (Total:8)
josagi
25 Ene 2017
kodilite_2.0
whats new:
-now dependencies included during installation so be sure ur connected to ur image feed to install dependencies when it ask during installation.
-latest updates from @pcd ( skin.xml )
-some latest plugins ytplus,Exodus,DCSports added inside.
thanx @pcd
https://mega.nz/#!nd9W0CJT!gdY2AregBdWbsW9ZZyq6Xlf7OXz3bdRYLKT-mqZ4n6A
josagi
25 Ene 2017
kodilite_3.0
whats new:
-latest updated plugins from @pcd : exodus ,xstream ,youtube ,iptvupdater
plugin.video.exodus - To reduce waiting time - in 'Setup' make unwanted providers 'false'.
plugin.video.xstream - In 'Setup' make wanted sites 'true' and hosterselect default 'List'.
plugin.video.youtube - Select 'yes' in first screen.
plugin.video.iptvupdater - New experimental 'Play with tsplayer' method.
thanx @pcd
https://mega.nz/#!jMtSGapQ!uCUc4HaF6U6ivMhfTBdQ_V7HomogBYPcKPCptDsjuF8
josagi
25 Ene 2017
New addons for KodiLite attached below.
plugin.video.dramasonline - Pakistani tv shows.
Method : Unzip and post the addon to folder :- /usr/lib/enigma2/python/Plugins/Extensions/KodiLite/plugins
Thanks pcd.
https://mega.nz/#!rU0UiTKT!sZPsDuA7YZB9lVDotGYe93VBvALAkSdhPMXIl8OCzLg
josagi
25 Ene 2017
plugin.video.bbciplayer
plugin.video.exodus
plugin.video.phstreams - unzip and ftp to folder /usr
plugin.video.streamondemand
plugin.video.xstream - unzip and ftp to folder /usr
Thanks pcd.
https://mega.nz/#!PQciiaBQ!y5-e6tcG-4egZZjCYDvNN7cz2VjHCpNE524r0NKmufs
josagi
25 Ene 2017
New addon for KodiLite attached below.
plugin.video.ZemTV-shani
ns
Thanks pcd.
https://mega.nz/#!HUswQJaS!RPwYZ453Bv3eFRASjCelPAGPSQqFCfjPH8Xrm2LfLos
josagi
25 Ene 2017
Updated addon for KodiLite attached below.
- plugin.video.ZemTV-shani - Unzip and ftp to /usr. For sports365.live use 'Play with vlc' option if 'Play with hlsplayer' not ok.
- plugin.video.specto
- kodilite-xxx-20170211 - Adult 18+
Thanks pcd.
https://mega.nz/#!yQF2QZSR!4SZS14yZndDFQ3n5oqe56mC54HEfqhaupHVvK-2L8hI
josagi
25 Ene 2017
Please unzip and ftp to /usr and restart enigma.
plugin.video.ZemTV-shani-1.0.3.zip - Sports Paktvsports has many international channels. Also live sports in sports365 (use vlc method).
Thanks pcd.
https://mega.nz/#!OE8jSIoS!OM3WQNODSL9EN8bB_qVVxwInE11EVAlAhU1yMny-GSg
josagi
25 Ene 2017
plugin.video.uiptv-1.0.0.zip - ultimate iptv from whitecream. Most items play with tsplayer.
Thanks pcd.
https://mega.nz/#!vE1FzDTC!hBiDQz4HznxVEeRMwNT5MNY37_0a8M9TRsIWIzDBnQ8
josagi
25 Ene 2017
plugin.video.adriansports-1.0.0.zip
https://mega.nz/#!WQsSEZIZ!tuNdHJNEB33AyC4csK11MRHeBH5Ny9n_K2FYC_NP5u0
josagi
25 Ene 2017
plugin.video.filmehd - films with Romanian subtitle.
plugin.video.bbciplayer - thanks Nitro123 - most items play with hlsplayer
Thanks pcd.
plugin.video.bbciplayer-1.0.2.zip
https://mega.nz/#!mUkCkbjT!zmz51YxrZtt60f1zLb-xd9FklcvoWKbbUd1ljJSqHLk
plugin.video.filmehd-1.0.0.zip
https://mega.nz/#!fJMEhDYA!9spJzgbkNkykQoZ9SbchOgHMPKhLEVmSvSErYSAKNT0
josagi
25 Ene 2017
plugin.video.cartoons8 - Kids and Cartoons
plugin.video.disneyjunior - Kids and Cartoons
plugin.video.toddlerworldtv - Kids and Cartoons
plugin.video.arte_tv - Deutsche
plugin.video.atv_at - Deutsche
plugin.video.br3 - Deutsche
plugin.video.n24_de - Deutsche
plugin.video.tlc_de - Deutsche
Thanks pcd.
https://mega.nz/#!3IdQERoT!yivMUk_Q0skcoYPZVgJGjX35kyI5v2zG_AWwlem3drQ
K4YS3R
N0 H4G0 SH4R1NG!!
11 Sep 2009
kodilite_2.0
thanx @pcd
buenas, intento instalar esto en mi dreambox 800 con BH 3.0 y no me instala me da error.
hay q hacer algo mas q meter esto?
Ð
Тайна го
El plugin lleva estas dependencias:
Depends: python-json, python-pyopenssl, python-compression, python-html, python-pycrypto, python-textutils, python-email, python-sqlite3, python-requests
Por lo que para que se pueda instalar la imagen que uses debe llevar esos archivos instalados o estar disponibles para su intalacion en los repositorios de la misma, en caso contrario no se instalara.
paparazziglio
Banned
30 Nov 2010
muy bien explicado alguien sabe algo del tema no como algunos. muchas gracias por la informacion compañero.
josagi
25 Ene 2017
No se porque te quejas tanto, yo pongo los plugins sin esperar nada a cambio, llevo mucho tiempo haciendolo sin problemas por muchos sitios.
Cuando no sepas algo lo preguntas y yo te respondo, no hace falta hacer comentarios como el que acabas de hacer.
K4YS3R
N0 H4G0 SH4R1NG!!
11 Sep 2009
Тайна го;2701923 dijo:
como se si tengo esas dependencias y si no las tengo como hago para instalarlas...
alguien me dice algo?
K4YS3R
N0 H4G0 SH4R1NG!!
11 Sep 2009
dime que error te da y te lo miro
lo instale bien. o eso creo, meti el archivo .ipk en tmp lo instale desde el mando y a la hora de entrar en plugin lo primero q me aparece antes de abrir los plugin es
Algunos complementos no estan disponibles:
Extension/Kodilite (No module named KodiLite.plugin)
doy a ok y aparecen todos los plugin menos kodilite
josagi
25 Ene 2017
Este plugin no funciona con todas las imagenes, la única solucion es instalar otra imagen.
josagi
25 Ene 2017
plugin.video.1080pmovies_gw-1.0.0 - thanks Nitr0123 - server openload - needs pairing
plugin.video.adulthideout-18+-1.0.0 thanks Nitro123
plugin.video.dailymotion_com-1.0.0
plugin.video.irish.tv-1.0.0
plugin.video.streamondemand-1.0.2 - servers rapidvideo, fastvideo,megahd tested working.
Thanks pcd.
https://mega.nz/#!rF1SDaiY!_aObKxYpG9fzqGJ-wORn74ITJwTf0HpqBBFhAACIQ9s
josagi
25 Ene 2017
plugin.video.exodus-1.0.5
Thanks pcd.
https://mega.nz/#!LYUHGQJC!IotmauEyuVlwpYBXeAFcQZjRoul0hGr9_04qgnIFWA8
josagi
25 Ene 2017
plugin.video.exodus-1.0.6 - Search function corrected
plugin.video.specto-1.0.3 - Search function corrected
plugin.video.ytplus-1.0.3 - software added for some images
Regards, pcd.
https://mega.nz/#!mB0QlAJT!cpXtAhlX_SO_-uldOW1qDnzRHO0jPtevA1lP5l5ekp0
josagi
25 Ene 2017
New addons
20170307
plugin.video.cine-1.0.0 - needs python-sqlite3 (opkg install python-sqlite3) - thanks @sergiri
plugin.video.iptvpandasat-1.0.0
Regards, pcd.
https://mega.nz/#!HYlTkZxL!Jh02OAcfDLLWE16kH_yhujEuWyya_32n3AN9N_K4rrU
josagi
25 Ene 2017
The current update enigma2-plugin-kodilite-update20170313.zip is attached below
Metod for installation:
Ftp the .zip file to /tmp. Then give the telnet command :-
unzip -o -q /tmp/*.zip -d /usr
Restart enigma.
https://mega.nz/#!aZ9klDZB!4-RvG1b11W9YY9eqoFa29mtZ_To2r8wxPra989U6CcI
josagi
25 Ene 2017
New addon
plugin.video.jizzplanet-18+-1.0.0 - Adult - Must setup cachefolder in Config (KodiLite first screen yellow button)
Thanks pcd.
https://mega.nz/#!HE8yhLBC!7lMTK8WJgILCcPSMRGjqNPHpSfUDcc7x_S73p03Ciwg
josagi
25 Ene 2017
New addons
plugin.video.exodus-1.0.7 - Movies - thanks @Nitro123
plugin.video.specto.1.0.4 - Movies - thanks @Nitro123
plugin.video.tvalacarta-1.0.0 - Spanish
plugin.video.vstream-1.0.0 - French - mystream, nowvideo, exashare worked.
plugin.video.xstream-nightly-1.0.2 - German - thanks @Nitro123 - openload (with pairing) and streamcloud worked.
Regards, pcd.
https://mega.nz/#!XdMFlbZK!dsheTFVlesNpUggbslj8w81i7L54v4v_4X9dq043w0o
josagi
25 Ene 2017
Plugin KodiLite.v.2.0
Hello Friends,
Attached is a simple plugin KodiLite to use Kodi type addons in enigma2 boxes (those that do not have Kodi proper) . I hope you find it useful. The plugin is big because all necessary script modules are included. The addons themselves are relatively small.
Latest version : KodiLite.v.2.0
Note: Only requested addons will be made available and maintained. If you want any other (or get error with any uploaded addon) - please post your request.
Method : Tested Kodi addons can be installed online via button "Install addons" and deleted via button "Delete addons" in first screen. Addons will be updated online when necessary. Any other Kodi addons can be tested by ftp to folder /usr/lib/enigma2/python/Plugins/Extensions/KodiLite/plugins.
Tips: For any stream - first use 'Play'. If the stream stops - if you see 33% 66% etc - try 'Play with hlsplayer'. Otherwise try 'Play with tsplayer'. Last resort 'Play with vlc'.
Regards, pcd.
##### Movies (many items include tv)####
plugin.video.specto
plugin.video.exodus
##### TV ####
##### Sport ####
plugin.video.SportsDevil
plugin.video.wweonline
##### IPTV ####
plugin.video.uiptv
##### Kids & Fun ####
##### Music Youtube & Co ####
plugin.video.ytplus
##### Adult(18+) Protect with Parental PIN ####
plugin.video.b44
plugin.video.camtubechat
plugin.video.Dclip
plugin.video.heavyr
plugin.video.motherless
pluplugin.video.nvista
plugin.video.Spicytranny
plugin.video.Superzooi
plugin.video.twanza
plugin.video.wildfire2
##### International ####
-------------------------- Deutsche --------------------------
plugin.video.atv_at
plugin.video.br3
plugin.video.dmax_de
plugin.video.euronews_com
plugin.video.zdf_de_lite
-------------------------- French --------------------------
-------------------------- Indian/Pakistani -------------
-------------------------- Italian --------
plugin.video.raitv
-------------------------- Spanish -----------------
plugin.video.Catoal
plugin.video.cine
-------------------------- Turkish --------------------------
plugin.video.ukturk
https://mega.nz/#!jIEzBDYC!5Ydpy8f2QfZToURGn9eGKkOBYPdZHz_Yd_6a2jwIq5U
