iSetting E2 | Archivostv
iSetting E2
josagi
25 Ene 2017
iSetting E2
3.4.3 - (20.09.2018 07:00) * (Available updating):
Fixed the problem of the crash when updating the plugin when it was started by the decoder.
Fixed the problem of maintaining the plugin configuration and the Betatester certificate being updated (working from next versions).
Unfortunately, due to a bug in the IPK installation package of v3.4.1, when updating manually or from the decoder, it is likely that the configuration is not maintained and therefore you are forced to remap all the parameters of the Plugin.
This BkConfiSettingE2 script (to be used via telnet with 775 permissions) helps to perform a quick backup of the configuration, before starting the installation of v3.4.3, manual with IPK or directly from the decoder.
During installation the package will automatically restore the configuration of the Plugin that you had previously saved.
No problem with the update package with .tar.gz.
Thank's to Diamondear
BkConfiSettingE2.rar
https://mega.nz/#!bJsjjRbC!IF1p6pDxKFmCIXrLTChndA7QYBo841KSjZttNFR5rwk
enigma2-plugin-extensions-isettinge2-3.4.3-oe2.0-all-mips.ipk
https://mega.nz/#!yE01hZRA!luT5lJVA6rPLpC8gP5hsJ4suvwvU2SpYG6_Hnqb-CMs
enigma2-plugin-extensions-isettinge2-3.4.3-oe2.0-all-arm.ipk
https://mega.nz/#!aR9BQDSK!REPrPEvU0_9mPVu-r7yRG_QpsAOf9OYctIPjwdrkdhg
