- Registrado
- 2 May 2006
- Mensajes
- 1.992
- Me gusta
- 1
- Puntos
- 0
Desconectado
Installation:
Just put Hadu.dll and Hadu.ini into the directory relative to plugins, regarding your current DVB software. It can be the directory of the software (i.e. for old versions of ProgDVB), or a given subdirectory (i.e. ./Plugins for MyTheater and Alt-DVB, ...).
As it is compatible with the DVBCore API, use it as a DVBCore plugin (for DVBCore softwares) instead of using it with MDWrapper. With DVBViewer, use it as DVBViewer plugin instead of using it with SoftCSA.
Don't use two or more CardSharing Clients and/or SoftCam Emulators at the same time (like Yankse, S2Emu or VPlug), unless you know perfectly what you are doing.
Directories of installation for the main DVB softwares:
Put all the files (i.e. only Hadu.dll + Hadu.ini currently) in the same directory , as indicated hereafter:
-ProgDVB : main directory of the DVB software (or /Plugins subdirectory for version 4.38 or later of ProgDVB)
-Alt-DVB : /Plugins (or /Plugins/av0) subdirectory, and/or /Plugins/pip subdirectory for the pip, and others (/Plugins/av1 to Plugins/av2
-MyTheater, RitzDVB: /Plugins subdirectory (to use Hadu as a DVBCore plugin). Try to avoid the solution MDWrapper.dll in /Plugins subdirectory and Hadu in /MDPlugins subdirectory (MDWrapper is a workaround to make old MD plugins working with MyTheater and other DVBCore softwares)
-DVBDream 0.xx: /Modules subdirectory since version 0.85 (to use Hadu as a DVBCore plugin). /Plugins subdirectory (to use Hadu as a MD plugin) for precedent versions
-DVBDream 1.xx and above : /Plugins/pip00 and others (/Plugins/pip01 up to /Plugins/pip19) subdirectories, to use Hadu as a MD plugin
-WatchTVPro: /Plugins subdirectory (Hadu is using the TT Trick automatically if it is possible)
-HispaDVB: main directory of the DVB software for old versions, and /Plugins subdirectory since version 2. Hadu is no more using the TT Trick automatically for this software, because it is no more needed for HispaDVB version 2 and above
-MultiDec: main directory of the DVB software (Hadu supports natively the different versions of the SS1 firmware)
-DVBViewer: /Plugins subdirectory. Avoid the solution SoftCSA.dll in /Plugins subdirectory and Hadu in /MDPlugins subdirectory. Please, note that the CSA.dll (coming with the SoftCSA package coded by Pikachu) is recommended for faster unscrambling, though not absolutely mandatory. The CSA.dll must be located into the /Plugins subdirectory (or KeyPath2) or into the main directory of the DVB software. Otherwise, Hadu will use its own internal CSA algorithm (code kindly provided by courtesy of Pikachu. Thanks!). With DVBViewer version 3.4 and above, you can also use the FFDeCSA.dll (both with the CSA.dll) : depending of your DVB card, the 'Open whole Transponder' Hardware option in DVBViewer will have to be checked or not, to optimize the video/audio CSA unscrambling treatment.
The 'Has CI module' entry option into the hardware options of DVBViewer must be checked.
-DVBViewer recording service: /Plugins/Plugins1 to /Plugins/Plugins31 subdirectories. Allow this recording service to interact with the Desk, and set "Systray=1" for the concerned Hadu.ini files. Don't forget that it's impossible to connect to the same server twice (double login are rejected by CCCam servers).
-SkyView: /MDPlugins subdirectory
-DvbTn: /Plugins subdirectory (to use Hadu as a DVBCore plugin)
-WinSTB: /MDPlugins subdirectory
-DiavloB: /Plugins subdirectory (to use Hadu as a MD plugin, though the software is based upon the DVBCore SDK)
-MajorDVB: /Plugins subdirectory
-TSReader: /MDPlugins subdirectory
-WinClip: /Plugins subdirectory
Caution: For DVB softwares based on the DVBCore SDK, don't install Hadu as a MD plugin and as a DVBCore plugin (choose either the first or the second solution, but not both !). Same thing for DVBViewer.
Do not use the DLL TTTrick.dll: Hadu has its own TT Trick implemented.
Each time it is possible (Alt-DVB2 and DVBDream 1.xx, for instance) set the packet size for plugins to 184 bytes, to minimalize the delay for the decoding process.
+ info en el leeme interior
link:
FILEFRONT
link:
FILEFRONT
