Glass System Utility | Archivostv
josagi
25 Ene 2017
GSU ver. 6.87
- oscam info: fix oscam status
- added option to set refresh time oscam log
- oscam info: fix oscam readers
- fix osd ecm info
- added full support of FHD skins - autodetektion
- updated all screens - autoswitch to 32bit graphics if Full HD mode is active
added option of "direct activation" of ECM info press red button
(lowest priority and if image do not use red button as any fnc), can be
enabled/disabled in UCM settings (green - direct start of UCM, red -
direct start of ECM info)
- channel info: added alternative method of tyner type detection
Thx@shamann
https://mega.nz/#!CUkhgT5a!x6WbAtmv12P-ink3_daxg65Tm5SjWgTOImlSu5yFJRs
josagi
25 Ene 2017
GSU ver. 6.88
- system info: fix CPU using calculation
- system info: fix displaying FHD icons
update is available online
Thx@shamann​
enigma2-plugin-glasssysutil_6.88_all.ipk.zip
https://mega.nz/#!vBNyiZxS!0c7AUh3OPWBZ2jHyzLgJunivJuKQAC0s4S2XTiWacgc
enigma2-plugin-glasssysutil_6.88_all.deb.zip
https://mega.nz/#!fJdknDxY!HS4dJNhVzlr5FSOVhfC0y4ElWDUBalgldmc5pEUMjiY
josagi
25 Ene 2017
GSU ver. 6.91
- fix oscam ymod version detection
- added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
- fix/corections more of screens
Thx@shamann
enigma2-plugin-glasssysutil_6.91_all.ipk.zip
https://mega.nz/#!edcRlDpS!yZcgUl2EZW70msNo0qnPUmvQe4vvYKh8Do2_YgyS8n4
enigma2-plugin-glasssysutil_6.91_all.deb.zip
https://mega.nz/#!PYsBSRzS!Coy4p24foEvw0VnP4Xn2PjzhiUgxKDbOOAtmGmD4gcc
josagi
25 Ene 2017
GSU ver. 10.22
- added missed cz translations
- channel information: added enhanced support of bitrate plugin
- fix channel information
- fix arch type detection
- fix online update
Thx@shamann
enigma2-plugin-glasssysutil_10.22_all.ipk.zip
https://mega.nz/#!TYNTCR4A!Ja9gPTfUAehib8oenGOWYp5vwwqlPmAgPVhYc7VrUao
enigma2-plugin-glasssysutil_10.19_all.deb.zip
https://mega.nz/#!3ZNBVAZQ!5JaFI9rR35-gWnOEDnbHxM8ZN08vvUCr3GHl71L6Ukc
josagi
25 Ene 2017
GSU ver. 10.31
- crond management: added expert settings, changed skin part, some fixes
- updated cz/sk translations
Thx@shamann
enigma2-plugin-glasssysutil_10.31_all.ipk
https://mega.nz/#!OENyTSyJ!ZODbA1yWb9dQIxu2828XKsl2vJxb1LQijzSPfdAGkpw
enigma2-plugin-glasssysutil_10.31_all.deb.zip
https://mega.nz/#!jNF21CwZ!WoO0QEkdp4HFuGqTCU-U9B1VeD90RWxwx-uMEkANnuE
josagi
25 Ene 2017
GSU ver. 10.58
- ECM parser: fix CAID detection
- added detection of CryptoGuard
  • ECM parser: oprava detekcie CAID
  • pridana detekcia CryptoGuard
Thx@shamann
enigma2-plugin-glasssysutil_10.58_all.ipk.zip
https://mega.nz/#!XVFWgarQ!7wji6Vo5q3S-Y5nC5-caIDbxtCagLDh8qLC4wwpQQ7A
enigma2-plugin-glasssysutil_10.58_all.deb.zip
https://mega.nz/#!KUVmlSaI!K_cXzp5_UZ1ubDwsjoXwH8PrmenLpjnMnM9b5NublMo
