FreeServer plugin | Página 2 | Archivostv
FreeServer plugin
josagi
25 Ene 2017
FreeServer V_6.7.2
Correct the errors causing the crash
Updated IPTV sports listings
enigma2-plugin-extensions-freeserver_6.7.2_all.ipk
https://mega.nz/#!XJsRhSCA!axBfevlbYqupeYBSQJWdEKGVRhN2Y6mOgHk2aPHFsWU
josagi
25 Ene 2017
New update for FreeServer_6.7.5
Update iptv lists
Update servers number 2 and add other servers
enigma2-plugin-extensions-freeserver_6.7.5_all.ipk
https://mega.nz/#!iJd3gSwZ!TdQRLU9c4ER0PaA0ro7ZbnCfFFm73Sav02fvrV-L4M0
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.7.6_all ipk
-Correcting some errors in the plugin ...
-Change the skins and improve the loading and installation of Emus
-Add emu CCcam
enigma2-plugin-extensions-freeserver_6.7.6_all.ipk.rar
https://mega.nz/#!OBkyzCzC!LJYu_PMnxcIFjPcLP6F7p5PrJANTmIlgFPwcYGTj5BY
josagi
25 Ene 2017
New update for FreeServer_6.7.7
Delete the extra files as the size of ipk 837 Ko
Add KOORA ON LINE for IPTV
Adoption script version 5.8 at the request of a member of the Russian forum and will be added version OE2.5
In the future about God
enigma2-plugin-extensions-freeserver_6.7.7_all.ipk
https://mega.nz/#!GItjkQaQ!5YQkOO-f04YXUa1Fo2qpIpJ9od4MvhrFO1Je8Hp_qW8
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.7.8_all ipk
-Some fixes
-Deleted all the files and the extra lines and the plugin became more light
enigma2-plugin-extensions-freeserver_6.7.8_all.ipk
https://mega.nz/#!LYdylYQK!zEYeB11VLxaRUxVVjMOQCmrychDN3iPStN60Dvnw36c
josagi
25 Ene 2017
New update for FreeServer_6.7.9
new servers
Auto-update script enabled when you open the plugin is looking
for a new update to the FreeServer script and if there is no update Returns directly to the interface
Update iptv lists in KOORA ON LINE
Repair of servers 31 and 27
Add Servers Red-Cam, Golden-Cam
enigma2-plugin-extensions-freeserver_6.7.9_all.ipk
https://mega.nz/#!SVV2XKBK!mbE4NP16v_c2xZD6jsCM8J-hLczkUv6xrB8N76ahuJc
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.8.0_all ipk
-Update IPTV
-Update the FreeServer script
enigma2-plugin-extensions-freeserver_6.8.0_all.ipk
https://mega.nz/#!eJknSSpJ!ro9DwISLcTKPeu8iO5EEza8cLNcjNpCthmuVGILbUa0
josagi
25 Ene 2017
New update for FreeServer_6.8.1
Update IPTV listings for the FOOT ON LINE extension
Add Auto-Update for FOOT ON LINE iptv ch
Add servers to the freeserver script
Change Font showinfo
Update CCcam.providers and CCcam.channelinfo on 11/11/2019
enigma2-plugin-extensions-freeserver_6.8.1_all.ipk
https://mega.nz/#!HUlVHajA!bJJnjOaKuAC2-_NIfEhzzp9qQ1G-kQZGhS4M6NF-h48
josagi
25 Ene 2017
New update for FreeServer_6.8.2
Solve a problem (NO MODULE NAMED BOXBRANDING).
For anyone looking for French PPV channels in the French IPTV 008 menu as shown in the picture ...
enigma2-plugin-extensions-freeserver_6.8.2_all.ipk
https://mega.nz/#!GRk0ASDC!AGkUewaYmCxKN5hQYUUUBHlrVyRT9gRtIUFSPCXJGaY
josagi
25 Ene 2017
FreeServer_6.8.2
modified the latest version of the plugin so that it is compatible with the kernel 2.0, 2.5 and 2.6 (images DreamOS )
Download the file and unzip and send the resulting file to tmp and give this command to install
tar -xzf /tmp/*.tar.gz -C /
restart the box
enigma2-plugin-extensions-freeserver-6.8.2.tar.gz
https://mega.nz/#!yUUjjQrD!V0Ee1Ei6UsU85LwkAj-kFtO1MGHz4eU7Pbx5EK4qMqE
josagi
25 Ene 2017
New update for FreeServer_6.8.4
NEW Update module cfscrape version 2.0.8 modified by alzamer2 update to new javacheck (IPTV KOORA ON LINE) work now!...
realcccam, dreamcccam, worldsat.
enigma2-plugin-extensions-freeserver_6.8.4_all.ipk
https://mega.nz/#!Pd1iVApa!MCpKYnF6gRNS49aLYUWReSxk2l5uT7FQ3P3AMg7Byg8
cfscrape.rar
https://mega.nz/#!nB1EVKoQ!uRsWuUhG31ycEx4m3cyq7HFOx94ImtD9R6FhSJqbwRo
enigma2-plugin-extensions-freeserver-6.8.4.tar.gz
https://mega.nz/#!zF0wGI4Y!2PJ4FBEGNpP_RmKf8swTPF_4hBq1dIfX592zivT9NGU
picotaso
4 Jun 2006
hola compañeros alguien me explica por aqui o por privado para que vale este plugin ,si es como el tema iks o algo de eso entiendo saludos
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.8.5_all ipk
Update version 6.8.5 for freeserver plugin
In this version, codes and all scripts were modified to flow smoothly with DreamOS kernel 2.5 OE and 2.6 OE.
Added a Servin Magikamed
improved and adjusted to match the HD screen and FHD
enigma2-plugin-extensions-freeserver_6.8.5_all.ipk
https://mega.nz/#!HJVHVY6L!tetDkibq_3XzHYZHGAU7aDO72Lj7RJc1Cmm5uBquPIU
enigma2-plugin-extensions-freeserver_6.8.5_all.deb
https://mega.nz/#!WMNVUC6Z!OBBzIkPVED8CFQXKzTDmP75gtgwgSnyHSzkpPH5pKqQ
josagi
25 Ene 2017
New update for FreeServer_6.8.6
Some errors were corrected in the plugin when entering the menu
enigma2-plugin-extensions-freeserver_6.8.6_all.ipk
https://mega.nz/#!PcV3GCZZ!lTFY8SBQvfGx3f-ZrY8f4G9VfvLrtShnvEz89_4WUeI
enigma2-plugin-extensions-freeserver_6.8.6_all.deb
https://mega.nz/#!eMFziYKZ!o_uA1TxQqGY-tGXBOGNTgTe5FqfedJQ0oL6hBRCJEKw
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.8.7_all ipk
KOORA ON LINE has been canceled for core 2.5 and 2.6 (deb) processors.
All credits from nodjs ... etc have been canceled
It remains the kernel 2.0 for the arm and mips processors
Update the twenty servers and add some servers
Note: the automatic update does not work because the server is under maintenance, I will upload the files later, until the server returns to work ...
enigma2-plugin-extensions-freeserver_6.8.7_all.ipk
https://mega.nz/#!uYNjAKDT!wKd_lNoXtm6Kjei82-Mt6VpP5mL5HIISVDINclOd014
enigma2-plugin-extensions-freeserver_6.8.7_all.deb
https://mega.nz/#!fZEjzYLb!g2YuPqoYlbBj3en75drritI4CYwF-6jTx4ezufLSPus
josagi
25 Ene 2017
enigma2-plugin-extensions-freeserver_6.8.8_all
Issue 6.8.8 Free Server
Some Python files have been modified to make the blog run smoothly and well.
enigma2-plugin-extensions-freeserver_6.8.8_all.ipk
https://mega.nz/#!HQMGwIbL!7yOXvOHnkQxpm1fid-fq8M-WxRweHUB_OQ89tFirJM8
enigma2-plugin-extensions-freeserver_6.8.8_all.deb
https://mega.nz/#!mIcyzSxJ!iFaP743asgVcvI12Ox8w5T2RRh15H-MEkN93fMde7TM
josagi
25 Ene 2017
New version
enigma2-plugin-extensions-freeserver_6.8.9_all ipk
Correct all errors. Maybe this is the final version and the next updates will be through the server
enigma2-plugin-extensions-freeserver_6.8.9_all.ipk.rar
https://mega.nz/#!rN93nIQK!I5ge8AWk6aEOYaewxmrGzKzOV7YU-W4HJt91fhOBirg
enigma2-plugin-extensions-freeserver_6.8.9_all.deb.rar
https://mega.nz/#!eB1xhQKY!7UOI7zzUNv9pVwq9UYHPRkKxtzJ4o6CGKnsRAKrS_MQ
josagi
25 Ene 2017
enigma2-plugin-extensions-freeserver_6.9.1_all
New version 6.9.1 FreeServer
For updating openvpn servers and adding 10 servers to the United States of America
Note for those who do not work with openvpn, it should be deleted and reinstalled again using
The following commands:
opkg update
opkg remove openvpn
reboot
opkg update
opkg install openvpn
reboot
thank mino60
enigma2-plugin-extensions-freeserver_6.9.1_all.ipk
https://mega.nz/#!zYshiQ4Y!-505wLiqnoRtv5360rgznhYQUqQ4CrzxUgx-VlWBsXA
enigma2-plugin-extensions-freeserver_6.9.1_all.deb
https://mega.nz/#!7Zl3zCaZ!zoSpA2smshSPHGojN4UTt3TjK6w4EDVLrmb2WEQF6gw
josagi
25 Ene 2017
enigma2-plugin-extensions-freeserver_6.9.2_all
Pigeon vault 6.9.2 FreeServer
New addition of the Arabic, French and English languages, by choice, on the MENU blog
Adding a new knife to the weekly sports program, especially football
All these updates are from the work of Brother Hussein, may God reward him with good in what he offers to help users of Enigma 2
Add CCCAM and NEWCAMD POLAND AND GERMANY servers
thank mino60
enigma2-plugin-extensions-freeserver_6.9.2_all.ipk
https://mega.nz/#!zAURHKRA!YkpPITsTGs9Ix1I824b3LwjzjNDm3Jx_sL8TL1pezhU
enigma2-plugin-extensions-freeserver_6.9.2_all.deb
https://mega.nz/#!zQUhBCjK!QpHEGKXRL-r0wcU91C1obqlt1NG5mR1L9ea_VwcF96Y
josagi
25 Ene 2017
enigma2-plugin-extensions-freeserver_6.9.3_all
A new version of Flagship 6.9.3 FreeServer
Corrected some errors, including the knife and the version number
Realcccam server update gives the line a 5-day renewable line
To install the boards properly.
enigma2-plugin-extensions-freeserver_6.9.3_all.ipk
https://mega.nz/#!3RtVRCKJ!jgkAbFjQN4JXGmR9RmddNILubwPPiTXO_VSc2P2BGZw
enigma2-plugin-extensions-freeserver_6.9.3.deb
https://mega.nz/#!WYsnEKqS!Yhe6INNjDNay_ixWtLkXv2PT3WtUCO--ODV3ySMEwuU
willson_weis
2 Ene 2007
Buenas he instalado el ipk. Tengo un vu zero pero no tengo ni idea como se pone a funcionar esto. A ver si alguién me dice como se hace. Gracias y salu2
josagi
25 Ene 2017
enigma2-plugin-extensions-freeserver_6.9.5_all ipk
- Change the skin of Emus-Cam simulators
Add servers for 5 days and some servers that use captcha to the script ...
For those who do not have all the servers or bear only some of them and have a problem with wget used
Modified script where curl is used instead of wget We open parentheses here for reference
Until the script file talks continuously, that is, if we put the modified script into the files of the files
It will be erased and replaced by the one who uses or depends on wget, so it should be placed in the usr / script /
And give him a permit of 755 chmod while waiting for a new option feature to be added in the plugins that will activate it
Or disable automatic updating of the script in future updates ..
enigma2-plugin-extensions-freeserver_6.9.5_all.ipk.rar
https://mega.nz/#!TUNkzaLb!-sNMsOMMTj0DX2FXTJfEOP3_81Sp9x0xekZAh6At2bM
enigma2-plugin-extensions-freeserver_6.9.5_all.deb.rar
https://mega.nz/#!WdNiSa7Q!ZNW4ZUg18s3keathoDxUo-tEfD4Mlv3-JdG609-meH4
FreeServer.rar
https://mega.nz/#!SZUwhShL!QsFclBaWmTB-d-Rqb2-8P6of6yUANthoLUL4xmCmZb8
Instinto
28 Oct 2016
Hola
  • te descargas CCcam y arrancas
  • arrancas el Plugin y le das ala tecla amarilla del Mando y esperas unos Minutos
