...:::: DreamOSat Script ::::.... | Archivostv
josagi
25 Ene 2017
============ NEW VERSION 6.5-r0 ============
ADD 15.02.2018
- (3) pAnDaSaT bOaRd SotfCam Key Update by. Informed
- (5) OSCam Free Server ALL
- (53) INT 2017 Movies
- (54) INT 2017 Movies 2
- (55) pAnDaSaT Free IPTV
- (56) MediaPortal Install
- (56) MediaPortal GrayZone Install
- (yedek) TechSat Keys, Download Keys
- (yedek) TechSat Keys, Show Visible Channel
- (yedek) SotfCam.Key Update satupdate.net
- (yedek) SotfCam.Key, constant.cw, AutoRoll.Key softcam.tv
FIX 15.02.2018
- (0) DreamOSatScript info # bash dos2unix add,
- (2) PowerVU ALL Keys # "MTN Worldwide TV" edit,
- (2) PowerVU ALL Keys # "language" add,
- (4) CCcam Free Server # "URL" add,
- (52) INT IPTV # bash script edit,
- PowerVu/sids # "MTN Worldwide TV" edit,
- PowerVu/.au # "AFN AU Keys 9.0" EMM Key edit,
- (60) ALL PiconTranparent 220x132 45.0W-85.1E # p7zip edit,
DELETE 15.02.2018
- (3) OSCam Free Server Freecline.com delete,
- (6) N-Line Free Server Freecline.com delete,
enigma2-plugin-extensions-dreamosat-script_6.5-r0_all.ipk
https://mega.nz/#!SBdhRagb!H5YlEieRiTaTLz_QrCcJUSNcs2rJbU0gXYRaYB0A2Lw
enigma2-plugin-extensions-dreamosat-script_6.5-r0_all.deb
https://mega.nz/#!KRsG0LAR!QUqdAzdXGgRlj1gZDtiLdHX_UC3k1rWhh-4bccVqb8A
josagi
25 Ene 2017
DreamOSat Script 7.0-r2 new version
Uyarı : Uydu alıcınızda mutlaka curl yüklü olması gerekiyor bazı scriptlerin saglıklı çalışabilmesi için
Piconları indirebilmek için p7zip gereklidir
============ NEW VERSION 7.0-r0 ============
ADD 01.03.2018
- (--) Katagorilere ayrıldı,
- (22) OSCam Free Server cccam3.com add,
- (31) N-Line Free Server cccam3.com add,
- (73) pAnDaSAT FREE ALL add,
- (74) pAnDaSAT ITALIA add,
- (75) pAnDaSAT INTERNATIONAL add,
- (76) pAnDaSAT MEDIAPLAY add,
- (77) pAnDaSAT SPORT add,
- (78) pAnDaSAT MUSICA add,
- (80) INT IPTV yilmaztv.com add,
- (81) INT IPTV DIZI yilmaztv.com add,
- (82) INT IPTV FILM yilmaztv.com add,
- (123) Biperva Settings 46E-42E-19E-13E-4.8E-0.8W
- (124) Chveneburi Settings 42E
- (125) Chveneburi Settings 42E-19E
- (126) Chveneburi Settings 42E-19E-13E
- (127) Chveneburi Settings 42E-19E-13E-7E
- (128) Chveneburi Settings 42E-19E-13E-7E-0.8W
- (129) Chveneburi Settings 42E-19E-16E-13E-7E-0.8W
- (130) Chveneburi Settings 42E-19E-16E-13E-7E-4.8E-0.8W
- (131) Chveneburi Settings 42E-23E-19E-16E-13E-7E-4.8E-0.8W
- (132) Chveneburi Settings 42E-23E-19E-16E-13E-7E-4.8E-1.9E-0.8W
- (133) Chveneburi Settings 42E-39E-23E-19E-16E-13E-7E-4.8E-1.9E-0.8W
- (134) Chveneburi Settings Motor 100.5E-30W
FIX 01.03.2018
- Python edit #Skins dosyaları kaldırıldı, python içerisine yazıldı..
- (2) PowerVU ALL SotfCam.Key # Discovery EURO KEY UPDATER,
- (62) MediaPortal GrayZone Install,
- (20) CCcam Free Server # curl max-time <seconds> 10 add,
- (21) OSCam Free Server ALL # curl max-time <seconds> 10 add,
- (22) OSCam Free Server cccam3.com # curl max-time <seconds> 10 add,
- (23) OSCam Free Server Testious.com # curl max-time <seconds> 10 add,
- (30) N-Line Free Server Testious.com # curl max-time <seconds> 10 add,
- (90) OSCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add,
- (91) OSCam EMU Updater dreambox_fpu OE2.0-OE2.5 # OpenATV 6.2 FIX, bash curl add
- (92) OSCam EMU Updater mips-openpli40 OE2.0 # OpenATV 6.2 FIX, bash curl add
- (93) OSCam EMU Updater [ARM] dreambox,vuplus,mutant,octagon,gigablue # OpenATV 6.2 FIX, bash curl add
- (94) OSCam EMU Updater dm900 LIBUSB OE2.5 # OpenATV 6.2 FIX, bash curl add
- (95) OSCam Updater armV7 (download.oscam.cc) # OpenATV 6.2 FIX, bash curl add
- (96) OSCam EMU Updater mips-tuxbox OE2.0 # OpenATV 6.2 FIX, bash curl add
- (98) NCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add
- (99) GCam EMU Updater ALL [mipsel,arm] OE2.0 # OpenATV 6.2 FIX, bash curl add
DELETE 01.03.2018
- Skin/menuhd.xml
- Skin/menufullhd.xml
enigma2-plugin-extensions-dreamosat-script_7.0-r2_all.ipk
https://mega.nz/#!bVVmVbpB!MKnk5JiQEaVwSOwu8CkzD6jU1QzcdtWjGFYN8jlvZKk
enigma2-plugin-extensions-dreamosat-script_7.0-r2_all.deb
https://mega.nz/#!WJ82CY6D!TzETTn_yi9L0PdrHxWuSidIcQrINjmCNIkoJDUojfZU
josagi
25 Ene 2017
Online Update
(0) DreamOSat Script Info çalıştırın (run start)
FIX 03.03.2018
josagi
25 Ene 2017
Online Update
== NEW VERSION 7.0-r3
ADD 13.03.2018
- (8) SotfCam.Key Update by.enigma1969
- (23) OSCam Free Server Freecline.com
- (24) OSCam Free Server cccam29.blogspot.com
- (25) OSCam Free Server webtechdz.com
- (29) OSCam Free Server smartcccam.uk
- (32) N-Line Free Server Freecline.com
- (150) Film Yerli Filmler
- (151) Film Turkce Dublaj
- (153) Film Altyazili
- (154) Film 4K
- (155) Film Imdb-100
- (156) Film Almanca
- (157) Film Dizi
- (158) Film Animasyon
- (159) Film Belgesel
FIX 13.03.2018
- (2) PowerVU ALL SotfCam.Key # SIS KEY UPDATER,
DELETE 13.03.2018
- (22) OSCam Free Server cccam3.com,
- (31) N-Line Free Server cccam3.com,
josagi
25 Ene 2017
Online Update
(0) DreamOSat Script Info ==> çalıştırın (run start)
== NEW VERSION 7.0-r4
Arkadaşlar, cihazınızda curl ve p7zip yüklü olması gerekir. eklentinin sağlıklı çalışabilmesi için, bunlardan biri dahi eksikse çalışmaz...
Bunları yükledikten sonra
Eklenti içine dirin ve (0) DreamOSat Script Info çalıştırın, kendini otomatik update yapacaktır.
Kurulum / install
opkg update; opkg upgrade
opkg install curl
opkg install p7zip
opkg install /tmp/*.ipk
ADD 06.04.2018
- (24) OSCam Free Server 1
- (25) OSCam Free Server 2
- (26) OSCam Free Server 3
- (27) OSCam Free Server 4
- (28) OSCam Free Server 5
- (29) OSCam Free Server 6
- (34) N-Line Free Server
- (38) OSCam TO NCam Converter
- (80) INT IPTV SR-1
- (81) INT IPTV SR-2
- (82) INT IPTV SR-3
- (83) INT IPTV SR-4
- (84) INT IPTV SR-5
- (85) INT IPTV SR-6
- (86) INT IPTV SR-7
- (87) INT IPTV SR-8
- (88) INT IPTV SR-8
- (89) INT IPTV SR-10
FIX 06.04.2018
- VTI Images fixed #skin ERROR SKIN component with name
- (2) PowerVU ALL SotfCam.Key # CHANEL SID ADD,EDIT,
DELETE 06.04.2018
- (2) PowerVU ALL SotfCam.Key # HBO/CineMax
Adjuntos
josagi
25 Ene 2017
Online Update
== NEW VERSION 7.0-r5
Kurulum / install
opkg install curl
opkg install p7zip
============ NEW VERSION 7.0-r5 ============
ADD 14.04.2018
- (59) OE2.5 Kodi (Xbmc) MediaCenter
- (74) INT IPTV Turkish Liste
josagi
25 Ene 2017
Online Update
(0) DreamOSat Script Info ==> çalýþtýrýn (run start)
== NEW VERSION 7.0-r6
Arkadaþlar, cihazýnýzda curl ve p7zip yüklü olmasý gerekir. eklentinin saðlýklý çalýþabilmesi için, bunlardan biri dahi eksikse çalýþmaz...
Bunlarý yükledikten sonra
Eklenti içine dirin ve (0) DreamOSat Script Info çalýþtýrýn, kendini otomatik update yapacaktýr.
Kurulum / install
opkg install curl
opkg install p7zip
============ NEW VERSION 7.0-r6 ============
ADD 27.04.2018
- (75) My Teledunet IPTV List #Yerli yabacý dünya geneli iptv kanallarý [2426] kanal
- (190) Picon Tranparent 220x132 19.2E (8.MB)
- (191) Picon White 220x132 19.2E (12.MB)
- (192) Picon Tranparent 220x132 13.0E (12.MB)
- (193) Picon White 220x132 13.0E (12.MB)
- (194) Picon Tranparent 220x132 30.0W (12.MB)
- (195) Picon White 220x132 30.0W (12.MB)
- (110) OpenVPNbook Free Server #1: Euro1 UDP53
- (110) OpenVPNbook Free Server #1: Euro1 UDP25000
- (110) OpenVPNbook Free Server #1: Euro1 TCP80
- (110) OpenVPNbook Free Server #1: Euro1 TCP443
- (111) OpenVPNbook Free Server #2: Euro2 UDP53
- (111) OpenVPNbook Free Server #2: Euro2 UDP25000
- (111) OpenVPNbook Free Server #2: Euro2 TCP80
- (111) OpenVPNbook Free Server #2: Euro2 TCP443
- (112) OpenVPNbook Free Server #3: US1 UDP53
- (112) OpenVPNbook Free Server #3: US1 UDP25000
- (112) OpenVPNbook Free Server #3: US1 TCP80
- (112) OpenVPNbook Free Server #3: US1 TCP443
- (113) OpenVPNbook Free Server #4: US2 UDP53
- (113) OpenVPNbook Free Server #4: US2 UDP25000
- (113) OpenVPNbook Free Server #4: US2 TCP80
- (113) OpenVPNbook Free Server #4: US2 TCP443
- (114) OpenVPNbook Free Server #5: CA (Canada) UDP53
- (114) OpenVPNbook Free Server #5: CA (Canada) UDP25000
- (114) OpenVPNbook Free Server #5: CA (Canada) TCP80
- (114) OpenVPNbook Free Server #5: CA (Canada) TCP443
- (115) OpenVPNbook Free Server #6: DE (Germany) UDP53
- (115) OpenVPNbook Free Server #6: DE (Germany) UDP25000
- (115) OpenVPNbook Free Server #6: DE (Germany) TCP80
- (115) OpenVPNbook Free Server #6: DE (Germany) TCP443
- (116) OpenVPNbook Free Server #7: FR (France) UDP53
- (116) OpenVPNbook Free Server #7: FR (France) UDP25000
- (116) OpenVPNbook Free Server #7: FR (France) TCP80
josagi
25 Ene 2017
Online Update
== NEW VERSION 7.0-r7
Kurulum / install
opkg install curl
opkg install p7zip
============ NEW VERSION 7.0-r7 ============
ADD 04.05.2018
- (170) Turkish (TV Series) #Haftalik diziler
- (171) Vikings (TV Series)
- (172) Game of Thrones (TV Series)
- (173) Britannia (TV Series)
josagi
25 Ene 2017
Online Update
(0) DreamOSat Script Upgrade ==> çalýþtýrýn (run start)
== NEW VERSION 7.0-r8 ==
Eklenti içine dirin ve (0) DreamOSat Script Upgrade çalýþtýrýn, kendini otomatik update yapacaktýr.
OE 2.0 Images Kurulum / install
opkg update
opkg upgrade
opkg install --force-depends --force-overwrite --force-downgrade curl
opkg install --force-depends --force-overwrite --force-downgrade p7zip
opkg install --force-overwrite --force-downgrade /tmp/*.ipk
OE2.5 DreamOS Images kurulum / install
apt update; apt upgrade
apt-get install --yes --force-yes --assume-yes curl
apt-get install --yes --force-yes --assume-yes p7zip
dpkg -i /tmp/*.deb
apt-get -f --force-yes --assume-yes install
============ NEW VERSION 7.0-r8 ============
ADD 15.05.2018
- (---) Python edit #Bazý imajlarda eklentiden atma sorunu giderildi.
- (150) Film Yerli Filmler 2 #Add/Eklendi.
- (151) Film Turkce Dublaj 2 #Add/Eklendi.
- (160) INT ALL Movies #2018 & 2000 Years #Add/Eklendi.
FIX 15.05.2018
- (21) OSCam Free Server ALL #Curl zaman aþýmý kýsaltýldý.
- (74) INT IPTV Turkish Liste #Edit
DELETE 15.05.2018
- (69) pAnDaSAT ITALIA # Delete/Silindi
- (70) pAnDaSAT INTERNATIONAL # Delete/Silindi
- (71) pAnDaSAT MEDIAPLAY # Delete/Silindi
- (72) pAnDaSAT SPORT # Delete/Silindi
- (73) pAnDaSAT MUSICA # Delete/Silindi
Adjuntos
josagi
25 Ene 2017
Online Update
== NEW VERSION 7.0-r9 ==
[COLOR=#939393]opkg update
opkg upgrade
[/COLOR]
[COLOR=#939393]apt update; apt upgrade
dpkg -i /tmp/*.deb
apt-get -f --force-yes --assume-yes install[/COLOR]
============ NEW VERSION 7.0-r9 ============
ADD 01.06.2018
- (91) OSCam Modern EMU Updater ALL [mipsel,arm] OE2.0-OE2.5
- (93) OSCam Modern EMU Updater dm900 LIBUSB OE2.0-OE2.5
- (96) OSCam EMU Updater [sh4-amino] OE2.0
- (97) OSCam EMU Updater [sh_4-qboxhd] OE2.0
- (100) CCcam EMU Updater ALL [mipsel,arm] OE2.0-OE2.5
- (101) MgCamd EMU Updater ALL [mipsel,arm] OE2.0-OE2.5
- (102) WiCardd EMU Updater ALL [mipsel,arm] OE2.0-OE2.5
FIX 01.06.2018
DELETE 01.06.2018
- (95) OSCam-svn Updater armV7
- (96) OSCam Updater mips-tuxbox-oe2.0
- (97) OSCam Updater mips-tuxbox-oe1.6
