Blac Hole 3.0.8 | Archivostv
Blac Hole 3.0.8
josagi
25 Ene 2017
BlackHole 3.0.8 release 24.12.2018
Whats New:
Many bug fixes
Added Serviceapp with Exteplayer3
New Bootlogo
Updated Mediatree to support more USB tuners
Updated Duo4K Drivers​
BH 3.0.8 onwards includes ServiceApp and Exteplayer3 which gives improved media playback /
streaming performance.
It is pre-installed in all boxes, except Gen1 Solo, Duo, Uno, Ultimo and Zero,
so you will have to enable it from the BH SpeedUp menu on those boxes.
To use it with IPTV, you can either leave the ServiceApp settings as default
and in your IPTV lists, just change the #SERVICE 1:0:1: or #SERVICE 4097:01: to #SERVICE 5002:0:1:
Doing this, Exteplayer3 will only be used on your IPTV streams.
Or you can change the default setting of Enigma2 playback system in the ServiceApp menu from Original to Exteplayer3.
Note: that you can not record IPTV streams if you are using Exteplayer3 (however Enigma2 isn't reliable when recording IPTV anyway).
Changing the setting in the ServiceApp menu,
means that the image will no longer use the built in Mediaplayer (linked to Gstreamer)
and will use ExtePlayer3 for all media playback for IPTV and streaming aswell as any movies / recordings on your hdd,
doing this you won't need to convert your IPTV lists to #SERVICE 5002:0:1:​
Main functions of the buttons on the remote:
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Hole Blue Panel
Blue button and then Red button = Black Hole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Audio menu
Green button = Black Hole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red short press= access HbbTv functions
Button Red long press= Red Panel (Parallel Universes Teleportation)
Addons
Addons Download Manager (Manager for package downloading)
Online Feeds Settings update
Online Black Hole image update
Manual Install BH packges (Manual installation of Black Hole packages)
Manual Install IPK packages (Manual installation of IPK packages)
Addons Uninstall Panel (Uninstalled packages)
Black Hole Statistics (See connections, top downloads and more)
Characteristics of BlackHole Panels
Red Panel
BH Parallel Universe Teleportation
BlackHole
Avalon
Chaos
Ghost
ServiceApp and Exteplayer3 are both external plugins, and are not part of the BH image, therefore any users that do not want / need to use these plugins, can remove them via the BH SpeedUp panel.​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.?
>>BH -3.0.8 -vusolo 4k <<
