Actualizaciones BlackHole 3.0.9 | Archivostv
Vmax
1 Nov 2013
The latest Black Hole image is 3.0.9.A Multistream
update drivers(duo2, solo2, solose(v2), zero)
  • Fixed demux(incorrect pid)
  • Fixed DVB-CI init.
  • Fixed Misc.
* THIS IS ONLY AS AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 *
* IT IS RECOMMENDED TO ONLY USE BH 3.0.9 IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno *
Vmax
1 Nov 2013
The latest Black Hole image is 3.0.9.B Multistream
Fix bug in BH Weather (stop image crashing if your city is not available).
Update Exteplayer3 (you can not use subtitles with Exteplayer3 otherwise image will crash).
Add Astra-sm to feeds for T2-MI support (for boxes that support MIS only).
* THIS IS ONLY AS AVAILABLE AS AN ONLINE UPDATE FROM 3.0.9 / 3.0.9.A *
* IT IS RECOMMENDED TO ONLY USE BH 3.0.9.x IN OMB (OpenMultiboot) with Vu+ Solo, Duo, Uno models *
jarito
29 Jun 2006
    • Fixed Misc.
